Creating Multiple Cases from a single template case.
I have a task to give Internal users ability to create a case for external users.
Internal users can create a few cases and publish them. Then external user will log in his portal and select what type of case he wants to use to initiate is case.
Im thinking there should be a Create case step but it should not be a parent child case relationship. since external user will basically select a template created by the internal user.
any ideas or explanations would be helpful.
Thank you.
