Mashup issue : Redirection appears to be in a loop, terminating request
Hi all,
We want to deploy a customer portal through the Mashup, we are yet using the gateway and under 7.2.1.
The challenge I am facing at this moment is accessing through Mashup to the application itself.
If I access directly, in the browser, through the authentication service - Then it works properly (user is reidrected to external credentials screen and then back to Pega with the token, which we get using OAuth2).
If I try to access through the Mashup, I always get the following error : "Redirection appears to be in a loop, terminating request : https://xx.xx-yyyy.xy:3822/prweb/IAC/!STANDARD/null/?pyActivity= ... "
I am kind of concerned on the "null" part, which does not show when accessing via browser and auth servlet (following is the url generated) :
https://xxx0333.xx-xxx.xy:443/prweb/IAC/5KeNFip5TiObG5wSB9hLNG8bJhFniUyy*/!STANDARD?pyActivity=Data-
Portal.ShowDesktop
Has anyone gone through this before? I have tried setting the setsecurecookie to true (as we have in the configuration of the gateway) but still getting same issue.
Many thanks in advance!
check the related posts here. One local solution is to setsecurecookie to false. Have you tried that?
