Map Value or Decision table
Which one is better when making decisions based on values of one or more properties ?
it says in PDN that "If you're making decisions on the basis of only 1 or 2 values, then use MapValue", but we can achieve the same with decision table what is the advantage of using Map value and In what scenarios we should use Decision table when making decision on the basis of more than 2 values ?
