Accenture
Last activity: 18 Dec 2015 7:53 EST
Edit in Excel of Decision Table/Map Value is not working in Pega 7.1.7
When clicked on Edit in Excel , it does not open Excel sheet to view the Decision Table or Map Value
Tried solution is Reintall the plugins from cab installer.
Accenture
They provided 4 hot fix for dt and map value issue
| Hotfix ID | Description |
| HFIX-23619 | Excel Macro for Decision Tables and Map Values need resigning |
| HFIX-23684 | Excel changes not saved , Map Value ruleform remains locked |
| HFIX-22815 | Edit Excel option is not updating changes back in PEGA with IE11 |
| HFIX-25305 | Request to front port the HFix-23555 to PRPC v7.1.7 |
Hi
Which browser you are using ?
And secondly, have you checked this article : https://community.pega.com/support/support-articles/unable-use-excel-edit-decision-table
Accenture
I m using IE 11, this article seems to be having issue while saving the excel file.
I m not able to open.
https://collaborate.pega.com/question/unable-edit-excel-decision-table-windows-10office-2016-prpc-62
This article seems to be the one which relates to me âº
Hi
thanks for pointing the SA item.
Since you are in 717 I think HFIX-25305 should work at your end.
Please contact Global customer support and raise an SR with them asking for this fix.
Please specify this mesh discussion so that the GCS engineer can see all the information we exchanged here.
Hey Rasaiya! Let us know if you open an SR please by replying with the SR number and we can track for you.
Thanks!
Accenture
