Accenture Singapore
SG
Last activity: 5 Apr 2021 15:24 EDT
Decision Table not returning a value
I am calling a Decision Table from an activity using property-map-decisiontable method after obj-browse method and I could see the decision table return values in the temp page (ex: steppage.pxResults(1).
Whereas, I am calling a Decision Table from an activity using same property-map-decisiontable method after Rdb-List method instead of obj-browse. Here, the decision table values are not being returned to the temp page...
Why the values are not being returned, if we call the decision Table after RDB-List method??
Whereas, the values are being returned as expected, if we call the decision Table after Obj-browse method....
Hello All,
It got resolved. The issue is with the connect SQL rule as the columns specified in the select clause are case sensitive...
