Machine gets logged off when its specified robot is stopped
Here is my issue. When I stop the robot from Pega Robot Manager portal, the machine where it is configured is getting logged off. And Pega Runtime is also stopped.
In order to restart the robot, I have to manually turn on the machine and launch the Pega Runtime.
Is there a workaround for this?
TIA
This is a default behavior if you stop your bot from Pega Robot Manager Portal.
To avoid this either of the two options would work for you.
First one is very obvious to stop the bot from Virtual Machine itself by exiting the Pega Runtime application from tray icon menu.
Second option is install Pega RPA Service in your virtual machine and set the mode to "OnDemand" in RPAService.config file.
With this you would enable the functionality to "Start" the bot on demand from the Robot Manager Portal.
Please refer the following link given below
https://community.pega.com/knowledgebase/articles/pega-rpa/robotic-processing-automation-rpa-service
-V.S.
