Anthem Inc
Last activity: 12 Jun 2020 8:52 EDT
Pega Robotics The Activity Does not Have A Property Named
Hi team.
Robotics Studio version: 8.0.2033.0
Pega version: 7.3.1
I'm developing an RPA robotics solution with two properties from Pega for one of my activities.
I created a robot activity. I have set the class. I can choose the fields and add to the collection. I can use the fields/properties in my automation. The project is effectively launched from Pega.
When the project runs, one of the properties is not coming to the robot with a log message "The '<activityName>' activity does not have a property named: '<propertyName>'. Setting to default value."
The property exists in Pega and is added to the relevant records for the configured class.
I am able to connect to the configured class and select the property from the list to include in my automation.
The property is populating with a value on the work object in Pega.
In studio: I have tried cleaning and building the solution several times. I have tried emptying the project cache folders. I have tried rebuilding the robot activity after completely deleting it.
In Pega: I have tried removing from relevant records and adding it back again. (I'm not sure if it is important, but the property doesn't appear on a search. I have to use "old:" to see it.)
I do not know if the second property is discovered correctly when the robot runs because the project fails due to the first one being set to null.
Hi team.
Pega version: 7.3.1
Please let me know if there is something else I should be doing.
Thank you,
Steve
