LDAP2 Authintication Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation.
I am trying to login using LDAP2 and getting below error. WC:01.01] (.authentication.SchemePRCustom) ERROR carepath-uat.wellcare.com|xx.xx.xx - Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation. The most likely cause for this is that your Data-Admin-AuthService record attempts to map directory attributes to PROPERTIES THAT DO NOT BELONG TO DATA-ADMIN-OPERATOR-ID class. Check your D-A-AuthService record for bad entries or typos. When i change the default access group in my Operator-ID profile, i can access but only one access group is creating the problem. That access group is associated with my AD group. rest access groups not creating any problem.
