Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation
I'm getting this error when logging in. Other users are able to login without any issues.
"Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation. The most likely cause for this is that your Data-Admin-AuthService record attempts to map directory attributes to PROPERTIES THAT DO NOT BELONG TO DATA-ADMIN-OPERATOR-ID class. Check your D-A-AuthService record for bad entries or typos."
What properties could be in my Data-Admin-Operator-ID instance that is failing? How can I get my operator id fixed?
