UnitedHealth Group
Last activity: 6 Feb 2018 7:25 EST
JMS Fatal Exceptions
We are receiving errors in our logs: Steps to reproduce. Has anyone seen these errors:
File listener will read the File and gives each record as input to JMS queue and save the record data in Data base accordingly
If JMS cannot Process in first run , we have agent which again pulls the record from DB and resend it to JMS queue
JMS will do either of following may be case creation if that data does not exist in system else updates the existing case if that data is already associated with a case
After successful process Record will be updated as processed in Data base
2018-02-02 03:31:13,655 [default-threads - 41] [ STANDARD] [ ] [ CLMS:01.01.01] (internal.database.ReporterImpl) FATAL JMS|UPMCReconMergeIntake|Services|ReconcileClaimMergeIntake|A470D09934E9676871574E5DC01B8C821 - The element at the top of the stack:
2018-02-02 03:31:13,655 [default-threads - 41] [ STANDARD] [ ] [ CLMS:01.01.01] (internal.database.ReporterImpl) FATAL JMS|UPMCReconMergeIntake|Services|ReconcileClaimMergeIntake|A470D09934E9676871574E5DC01B8C821 - Element being removed
java.lang.Throwable
could you please attache complete logs
