Connect-JMS failing with following exception
Any suggestions on below exceptions.
** Couldn't create session objects: com.ibm.msg.client.jms.DetailedInvalidDestinationException: JMSWMQ2008: Failed to open MQ queue 'PMIT.VS.CUSTOMER.LOCATE.INQUIRY10.02'.
JMS attempted to perform an MQOPEN, but WebSphere MQ reported an error.
Use the linked exception to determine the cause of this error. Check that the specified queue and queue manager are defined correctly.
