Is it possible to run either pyAgeByFlowAssignment or pyProcessStepDuration for every work pool/case type in the system, once the work pool filter has been removed?
After removing the work pool filter from pyAgeByFlowAssignment or pyProcessStepDuration, the report is still defaulting to a work pool - one work pool in the developer portal, and a different one in the manager portal. I would like the report definintion to return results for all work pools in the system on one report. Is it possible to run either of these reports for every work pool/case type in the system, once the work pool filter has been removed?
Message was edited by: Kip Jackson Modified Title
