Infosys
Last activity: 17 Jan 2018 13:54 EST
Issues in CPM Healthcare Framework, or maybe in CPM framework too
In our application, We have a rule named “UHGCPMSInteractionPortalTop” which is a copy and minor customization of out of box rule "CPM-Portal.CPMHCInteractionPortalTop" in CPMHC-UI:07-13-01
(see attached document for screenshot)
from CPM Healthcare frame work.
In this rule, layout 2 has Refresh condition
“D_CPMPortalContext.pyID Changes || D_CPMPortalContext.InteractionHeaderRefreshDateTime Changes”
When we run the application, whenever a new intent is launched from interaction, or an intent makes progress in the flow, such as submit a flow action, then the layout aforementioned in the header refreshes itself, even though neither D_CPMPortalContext.pyID or D_CPMPortalContext.InteractionHeaderRefreshDateTime changes, both remain the same.
Investigation shows that PRPC server somehow thinks that D_CPMPortalContext.pyID has changed, and tells the browser the same, causing browser to refresh the layout aforementioned.
Has anyone noticed same issue in your CPM application?
***Edited by Moderator Marissa to add SR Details***
