Swedbank AB
SE
Last activity: 25 Dec 2017 2:19 EST
Issue in requirement set load
As part of my application build i am loading requirementset, requirements, documents. But in GenerateDocsfromDocGrp activity step 9.4,9.5,9.6 hardcoded with pyworkpage due to that my documents are loading. Some one can explain why this steps are hardcoded . In private if i change to primary instead of pyWorkPage i am getting documents. Becuase while case creation i am calling this utility and page will be iterate page.
So pega should not expect pyWorkPage all the time . I have seen this issue in OOTB Addcontact(PEGAOBFS-Work-AddContact) flow aswell
Deva.
Since it is an available rule, you always have the flexibility to modify the code as per your need. While developing, they mightn't have considered all use cases.
