Required settings for Reverse Proxy
We are planning to have a Reverse Proxy up front before load balancer & Pega app servers. Below PDN article describes the required settings around XF-*:
https://pdn.pega.com/deployment-behind-reverse-proxy/deployment-behind-reverse-proxy
In this table, X-Forward-Proto seems to be "required".
My question is is this really necessary? The reason I ask is, to do this is pretty costly and I just wanted to double check if it is true or not. Can someone please explain what exactly would be a problem if I don't set this X-Forward-Proto property?
