Interaction manager is unstable, is there any other way to call the variant under different projects within one solution
The interaction manager is unstable, sometimes it works well, sometimes can not find the properties i defined.
reload the xml file again and again, rebuild the solution again and again.
i like the interaction manager and also hate it.
it helps me call the variant under different projects, but it often goes to crash when i show my automation to my 'customers'.
If you're only working with one project then you should be using configurations.
http://help.openspan.com/80/Project_Configuration_and_Deployment/Project_Configuration2.htm
