Multiple project in one single solution
Im trying to connect the multiple projects to my main solution. I already added the references. But, every time I try to run the main automation, it will always run twice at the same time. The first one will be successful and the second one will always end with error, these two will always run at the same time.
Can anyone help with the multiple project in one solution?
We'll need more information regarding what is happening. If you are running from Studio, then perhaps you have a circular reference. If you are loading the project from Runtime, I do know of a defect where the AllProjectsStarted event will fire twice if you use Load Local Project in Runtime. My suggestion would be to open an SR with support as this is likely too complex to resolve here, but simple once someone can get to your machine and examine the logs. If you do open an SR, please post the SR number here for tracking purposes. The following article will be help you in creating an SR-
My Support Portal explained for Pega Robotic Automation (formerly OpenSpan)
