Infosys
Last activity: 12 Mar 2025 15:47 EDT
Integrating Knowledge Buddy with Pega Knowledge
I have created the Knowledge Buddy and Pega Knowledge app in 24.2 lab instance. I followed the following article to integrate both the applications, but still not able to automatically ingest the content that I have created in the knowledge portal into the knowledge buddy.
Getting the error 'Failed to reindex the article text into Knowledge Buddy', when I try to manually sync the published articles.
What other steps need to be followed for the content to get automatically ingested into the Knowledge Buddy application?
@UtsabBora1998 please can you confirm if your issue is resolved?
Did you carry out a key word PSC search?
Pega Knowledge Buddy on a Trial (Lab) Environment
Error while using Pega Knowledge Buddy Gadget (Constellation - Community Edition)
Unable to find Knowledge Buddy chat icon and Ask Buddy widgets in the Knowledge Buddy portal (Pega Labs)
"If you are licensed then you will be provisioned with a vector store service which is a requirement for using Buddy. If you are licensed, please file a ticket with support. Note: Buddy ONLY works on a Cloud-3 instance. There is no other place to install a buddy and have it supported".
If you can provide the solution in a reply and mark it with 'Accept Solution' that would be appreciated.
Below is a GenAI-powered answer. All generated answers require validation against the provided references.
This is the systematic approach to resolve the "Failed to reindex the article text into Knowledge Buddy" error (for users provisioned with a vector store service and with valid license):
Here are the steps you should verify and complete in sequence:
For automatic ingestion to work properly going forward:
References
