Oversea-Chinese Banking Corporation Ltd
SG
Last activity: 7 Aug 2023 10:34 EDT
Impact on Pega Upgrade
Currently we are planning to upgrade our Pega environment form 7.1.7 to 8.3
We have tried to run the upgrade utility tool, but as suggested by Pega the tool works only when we migrate from 8.x to 8.x versions and not supported for 7.x to 8.x versions.
Also there is no list of deprecated rules in Pega 8.x versions, like Agents to Queue Processor.
Can some one suggest how to perform impact analysis on Pega Upgrade?
The idea to list the functionalities or code changes which will impact the upgrade and fix it once the upgrade process is completed.
Request your advice please
@JaikumarR1777 Request you to please let us know, are you upgrading only the pega platform version from 7.1.7 to 8.3 or along with platform is there any pega strategic application/pega framework that also is being upgraded.
for example you may refer below link if upgrading framework such as pega marketing.
https://community.pega.com/knowledgebase/documents/pega-marketing-7x-83-upgrade-guide
Alternatively you may follow the path of first upgrading your lower environment, remediate any post upgrade issues and proceed for further envieonments.
