Standard Chartered Bank
Last activity: 4 Jan 2017 5:58 EST
I get "Outbound data mapping failed " if I run SOAP service in the same instance again.I have to re login to run it again.
I have a SOAP service in the application.If I try to run a request from the service twice from the same instance i.e logged in once it says "Outbound data mapping failed " .But the request is same.If I relogin into the application again.I am able to run it.
Is it accepted feature of Pega that I can run SOAP service request only once per login?
PEG
Can you change the processing mode to "stateless" and try the scenario?
what is PRPC version you are using?
PRPC 6.2 SP2
Can you please share complete error trace when you see this issue?
This is Service Trace.There is no error in the activities called just an error at tha last in the service.
PEG
Can you check response mapping steps are valid or not in Service-Activity and Service-SOAP rule?
All the Steps are valid since it runs properly the very first time.
Please help me with this, since it is causing extra delay in testing the service.
PEG
Yes, it is correct that the service logic contains tags to fetch attachment details which later uploaded to a repository. Can this be the only possible cause?
PEG
I couldn't say this is the only reason. This could be the reason for getting outbound mapping failed.
So , changing the service activity logic is the only solution or there is some other way
PEG
I believe, changing the logic would do .
The file attachment logic is necessary part of the service. Can there be some other solution?
PEG
What happens if you run Service using tools like SOAP UI or tcpmon? Are you getting same error?
No. I can run the service as many as times from SOAP UI without any errors. The only issue is with Pega. If I login once and run the service twice the error comes for second request.
PEG
Is authentication enabled in Service Package data instance?
Yes it enabled.And the Processing Mode is "Stateful"
PEG
Keeping the Processing mode to "Stateful" is the project requirement. Can there be some other solution?
It was due to the stateless mode only. If you have any solution please let me knoe.
