Lanit
RU
Last activity: 14 Jul 2017 3:57 EDT
Failed to retrieve Rule-Service-SOAP instance XXX using default rulesets
Hello everyone!
We have a SOAP integration - two services, two WSDL. Services, service packages and other rules are made in the same way. Both service packages have the same Service access group.
Service #1 works correct - returns correct WSDL, returns correct responses for requests.
Service #2 works strange - returns incorrect WSDL (almost empty), returns an error for requests.
Returned WSDL:
Service response:
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<soap:Fault>
<faultcode>soap:Server</faultcode>
<faultstring>Failed to retrieve Rule-Service-SOAP instance SUDIRReferenceService.Services.getSupportingData using default rulesets (Data-Admin-ServicePackage SUDIRReferenceService doesn't exist)</faultstring>
</soap:Fault>
</soap:Body>
</soap:Envelope>
Of course Service package exists.
Hello everyone!
Returned WSDL:
Service response:
<soap:Body>
<soap:Fault>
</soap:Fault>
</soap:Body>
</soap:Envelope>
This problem occurs only on one environment - on the customer environment, does not reproduces on our dev and qa.
1. What is the reason of this error?
2. What is known as "default rulesets"? I thought that requestor gets standard access group PRPC:Unauthenticated and because of that he can't see Service Package from our application. But when I tried to set this AG if service package, I get another error: Failed to retrieve Rule-Service-SOAP instance SUDIRReferencesService.Services.getSupportingData using access group PRPC:Unauthenticated.
Environment was rebooted, service package was resaved, but no changes.
I've already created an SR SR-A100903 for this problem, but for now got no answer.
***Updated by moderator: Marissa to blur proprietary information in images, removed #helpme and Ask the Expert group tags. Apologies those should not have been available to users.***
