Coforge Ltd.
Last activity: 25 Jun 2019 13:55 EDT
How to resolve " Missing stream key property pyID"
Hi all,
Requirement is to launch a Harness form an activity.
I am using the OOTB activity "Show-Harness"
The parameters i am passing are- Purpose and the HTMLClass .
The Purpose contains the Harness name and the HTML class has the class name of the Harness rule.
I am getting the below error
"Missing stream key property pyID"
Please tell me how to resolve this.
Thanks in advance :)
For Show-Harness activity, you don't need to pass the parameter "HTMLClass" when the Purpose we are giving is of Harness(name of a harness rule). You can remove this parameter and try.
Santhosh
There are Articles similar to this and hence I believe that the issue would be similar for you.
https://collaborate.pega.com/question/how-resolve-missing-stream-key-property-pystreamname-when-calling-activity-work
Since I dont have info on the failure steps that tracer would show I would strongly recommend you to go through Java steps of Show-Harness activity.
Perhaps the last Java step would be throwing this issue.
Verify the PegaRules log to get the complete picture
Bug me for help!!
Ujjwal
I think it is expecting the pyID value. Use Pass Current Parameter Page option and set the value of pyID in the previous step.
Bernard Macours Pushpavalli Naina Mohanarangam Bukhari Shaik
Coforge Ltd.
Its Resolved.. Thank you all :)
It would be great if you can share the resolution
NASCO
What was the solution to this problem? I am having the same issue. Calling ReloadActivity fails with:
** Missing stream key property pyID |
NASCO
I decided to add a button to refresh the section instead of from an activity. The activity was causing a lot of issues.
Hi @NascoMan!
Thanks! Did that resolve this for you?
NASCO
Yes, it's resolved now. Manually calling ReloadSection from your own activity certainly seems to be discouraged.
Thanks @NascoMan! I've marked your previous reply as the Correct Answer.
Tekclan Software Solutions
