How to resolve Missing stream key property pyStreamName when calling Activity Work-.StartNewFlow from within Agent Activity
I have an Agent Activity. It loads a Sub-case via the appropriate handle. I want to invoke a Flow on the Sub-case. Under certain circumstances, this flow results in the cancelling of the sub-case. When I invoked the Work-.StartFlow the desired result did not work. The functionality works as desired when I invoke Activity Work-.StartNewFlow.
However, I continually get "Missing stream key property pyStreamName" when I run the Agent Activity manually.
This is coming from Step 13 of StartNewFlow.
Is the error a result of me triggering this Agent Activity manually?
Or is it because I have not set HarnessPurpose on the parameter to StartNewFlow?
When I tried setting the HarnessPurpose parameter to Perform it gave me many different errors and thus removed the setting of the value
Any assistance/help on which direction I should take to prevent this error from occurring? (stack trace ends up in application server logs)
(Pega Version: 7.1.8)
