Function working when running an activity, but not with an agent
Hello.
I'm trying to use the following in an activity:
@DateTime.addToDateYM(Param.CurrentDate,"0","-6","0","0","0","0")
(with Param.CurrentDate as a String or DateTime parameter, the problem is the same with both). The aim is to substract 6 months to the current date.
My activity is doing well when I run it but if an agent does, I keep having this message in the SMA:
Hello.
** ** 1228138309§addToDateYM§PegaEL-InvalidExpression No candidates found [possible function name, ruleset/version or number of parameter problem] for Rule-Utility-Function in ruleset list expected since isEditing is false ruleset = null library = DateTime functionName = addToDateYM parameters =[ Item: Param.CurrentDate Pega type = datetime Java data type = BigDecimal, Item: "0" Pega type = text Java data type = String, Item: "-6" Pega type = text Java data type = String, Item: "0" Pega type = text Java data type = String, Item: "0" Pega type = text Java data type = String, Item: "0" Pega type = text Java data type = String, Item: "0" Pega type = text Java data type = String] @DateTime.addToDateYM(Param.CurrentDate,"0","-6","0","0","0","0")
