How customize Assign-Worklist class using in portal
The SME would like several columns stocked in Work Object in the task list in portal.
The task list only returns lines from Assign-Worklist or Assign-Workbasket class.
So, we have added a join on report definition with the work object class but the performance are bad because this table is very big.
So, we try to customize the Assign-... class to stock the additional information. With this solution we can returns this information on report definition without add a join with the work object class. We have customized the NewDefault activity applied to Assign- Class to set this additionnal information and add this information on report definition used in Portal.
It's work fine but the new property are not optimize in the database table DATA.pc_assign_worklist.
We have tried to optimize this property but PEGA forbid it.
How customize this property to resolved our issue or have you an other idea to custom the assignment ?
I saw this article last week but there are not enough property in my case
https://pdn.pega.com/how-customize-display-worklist
Kévin
