How to change the Pega default icon for offline enabled application
We have a requirement that we need to show a customized icon/logo/image in place of Pega OOTB icon/logo/image after installing the application into our device. We have tried to change the images/logos/icons in the "branding-assets-advanced-7-30.zip" and also in "branding-assets-7-30.zip" by keeping the same name for the file and also in the same folder structure but we are not able to see any changes getting reflected. We have tried to change our customized icon/logo/image to the exact dimension and size of the Pega OOTB icon/logo/image but still we are not able to see the changes getting reflected. Can someone tell if there is some other step that we are missing except changing the icon/logo/image in the zip file and uploading it into the application.
Hello Sioni,
Thanks for posting your query in PSC :)
1. Do you see the behavior on both Android and iOS devices?
2. Verify if the format of the package is an issue. Refer PSC discussion thread.
3. Verify if branding-assets.zip file is organized correctly. Refer the Support Article in this regard.
Refer PDN help regarding contents of branding from Pega 7.4.
I hope this helps.
Rincy
