Hazelcast Best practices
Can someone elaborate on the best practices while configuring embedded (OR) client- server mode for hazelcast on Pega Platform ?
How to decide when to you use embedded mode vs Client/Server?
In few Pega documentation we found that the Hazelcast client-server model is intended for select environments running Pega Platform 8.4 or later across a large number of nodes and should be deployed only when directed to by Global Client Support.How many nodes are considered to be large?
In one of the LSA courses , it mentioned that large production environments with more than 5 cluster nodes should go for Client-Server mode for better stability .. Is that statement right?
