Lyance
Lyance
FR
Lyance
Posted: Jun 22, 2016
Last activity: Jun 27, 2016
Last activity: 27 Jun 2016 10:13 EDT
The expected behavior could be obtained when checked "Enable client side validation" on the Harness rule.
How are you setting the note?
Hi
I think validation will trigger when you manually enterring the value in the grid and skips one of the mandatory fields.
So I would also like to check, how you are trying to set the values against Note field ? Automatically ? or Manually ?
Also which PRPC version you are on ?
