CXForward
Last activity: 13 Sep 2018 12:50 EDT
GMT format used in audit trail when tracking a DateTime property.
We are tracking a DateTime property - DueDate for audit trail. When a value is added or changed for this property, the audit trail is recorded as:
- Added DueDate value '20180510T040000.000 GMT'
- Changed DueDate from '20180510T040000.000 GMT' to '20180518T040000.000 GMT'
We need it to display in user friendly format.
Tried to follow the article:
Not much information provided.
Thank you!
***Moderator Edit: Vidyaranjan | Updated SR details***
Hi Pramod,
These messages are coming from FieldValues. So if try to search pyHistoryMemo , you will get field values for above messages.
When you will open the field Value, you can see several parameters like {1},{2}....
Try to give pxDateTime control for your date time parameter in the similar way shown below:
Hi Pramod,
Like this you will be able to achieve your requirement.
Please let me know if you are facing any issue.
Thank you
-Abhishek
Hi Pramod,
Please modify the Due Date property to Date field in order to display the required field in the below format:
"20180518".
Poornachandra Veluri
CXForward
Hi Ankit,
The user needs it in "18th May, 2018".
Hi Pramod,
There is a OOTB DateTime-Short Control, which you use for the DateTime property .
And also select the format from Presentation tab of the property in section.
Thank you
-Abhishek
CXForward
Hey Abhishek,
The above solution did not solve the issue.
-Pramod
Hi Pramod,
Hi Pramod,
Thank you
-Abhishek
José Luis Laviña
In addition to that you can refer below link for field value:
CXForward
Thank you Abhishek. It worked! We had to use a custom - non auto generated control though. The auto generated control gave some trouble.
Capgemini
Can you share your customized control
Tata Consultancy Services
Could you please share me your custom control configuration.
Updated: 13 Sep 2018 9:08 EDT
CXForward
Hi Gayatri,
Hope this helps:
Field Value:
Custom Control:
Pramod
Capgemini
Thanks Pramod
