L&T Infotech
Last activity: 25 Aug 2017 23:59 EDT
Getting "Failed to compile generated Java" in Agent Activity
Can anyone help me when this exception occurs?, following is the exception:
11 Oct 2016 11:20:15,770 [ PegaRULES-Batch-3] [ STANDARD] [ Inv:01.03.01] (pcentric.RACacheAppCentricImpl) ERROR - Failed to generate com.pegarules.generated.flow.ra_action_bnymsendrofcorr_46d5a9f36d8c1d6c33fcaf46ff96b052
com.pega.pegarules.pub.generator.FirstUseAssemblerException: Failed to compile generated Java com.pegarules.generated.flow.ra_action_bnymsendrofcorr_46d5a9f36d8c1d6c33fcaf46ff96b052:
at com.pega.pegarules.generation.internal.assembly.FUAInstance.compileClass(FUAInstance.java:2912)
at com.pega.pegarules.generation.external.assembly.Assembler.compileClass(Assembler.java:1013)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.writeJavaFileAndCompile(AssemblyCacheBase.java:1887)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.writeJavaFileAndCompileAndLoad(AssemblyCacheBase.java:1814)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.buildAndOrLoadJavaClass(AssemblyCacheBase.java:1966)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheBase.getGeneratedJava(AssemblyCacheBase.java:3350)
at com.pega.pegarules.generation.internal.cache.appcentric.RACacheAppCentricImpl.addEntryToMemoryCache(RACacheAppCentricImpl.java:1091)
at com.pega.pegarules.generation.internal.cache.appcentric.RACacheAppCentricImpl.find(RACacheAppCentricImpl.java:952)
at com.pega.pegarules.generation.internal.cache.AssemblyCacheWrapper.find(AssemblyCacheWrapper.java:781)
at com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.getInternal(FUAManagerImpl.java:1315)
at com.pega.pegarules.generation.internal.assembly.FUAManagerImpl.get(FUAManagerImpl.java:1245)
at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:265)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3033)
at com.pegarules.generated.StartFlow_060301_76mi74kA4YFuE58COwrXuA.StartFlow06_03_01(StartFlow_060301_76mi74kA4YFuE58COwrXuA.java:167)
at com.pegarules.generated.StartFlow_060301_76mi74kA4YFuE58COwrXuA.invoke(StartFlow_060301_76mi74kA4YFuE58COwrXuA.java:76)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:132)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:109)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:7975)
at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
at com.pegarules.generated.pega_procom_flow.StartFlow(pega_procom_flow.java:614)
at com.pegarules.generated.StartFlow_060301_lO064hi7$3j9Xw2fZi_iqw.StartFlow06_03_01(StartFlow_060301_lO064hi7$3j9Xw2fZi_iqw.java:111)
at com.pegarules.generated.StartFlow_060301_lO064hi7$3j9Xw2fZi_iqw.invoke(StartFlow_060301_lO064hi7$3j9Xw2fZi_iqw.java:76)
at com.pegarules.generated.pega_procom_flow.StartFlow(pega_procom_flow.java:630)
at com.pegarules.generated.StartFlow_060301_wsofPRI4RxI31Ah75XYbiQ.StartFlow06_03_01(StartFlow_060301_wsofPRI4RxI31Ah75XYbiQ.java:102)
at com.pegarules.generated.StartFlow_060301_wsofPRI4RxI31Ah75XYbiQ.invoke(StartFlow_060301_wsofPRI4RxI31Ah75XYbiQ.java:76)
at com.pegarules.generated.pega_procom_flow.StartFlow(pega_procom_flow.java:622)
at com.pegarules.generated.activity.ra_action_flowticketevaluate_e3ba0c2bc2491dd6029ef1a2ad3c7835.step1_circum0(ra_action_flowticketevaluate_e3ba0c2bc2491dd6029ef1a2ad3c7835.java:207)
at com.pegarules.generated.activity.ra_action_flowticketevaluate_e3ba0c2bc2491dd6029ef1a2ad3c7835.perform(ra_action_flowticketevaluate_e3ba0c2bc2491dd6029ef1a2ad3c7835.java:72)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3040)
at com.pegarules.generated.activity.ra_action_resolvecase_4cdef8535e3d15374dd1cbd23fee9f85.step1_circum0(ra_action_resolvecase_4cdef8535e3d15374dd1cbd23fee9f85.java:441)
at com.pegarules.generated.activity.ra_action_resolvecase_4cdef8535e3d15374dd1cbd23fee9f85.perform(ra_action_resolvecase_4cdef8535e3d15374dd1cbd23fee9f85.java:72)
at com.pegarules.generated.activity.ra_action_actionresolvecase_57e8ce73e1ff27b69d1b70496da10802.step18_circum0(ra_action_actionresolvecase_57e8ce73e1ff27b69d1b70496da10802.java:2125)
at com.pegarules.generated.activity.ra_action_actionresolvecase_57e8ce73e1ff27b69d1b70496da10802.perform(ra_action_actionresolvecase_57e8ce73e1ff27b69d1b70496da10802.java:426)
at com.pegarules.generated.activity.ra_action_autoresolvecase_47813226689a10d06863ceaf2ad46714.step6_circum0(ra_action_autoresolvecase_47813226689a10d06863ceaf2ad46714.java:975)
at com.pegarules.generated.activity.ra_action_autoresolvecase_47813226689a10d06863ceaf2ad46714.perform(ra_action_autoresolvecase_47813226689a10d06863ceaf2ad46714.java:157)
at com.pegarules.generated.activity.ra_action_cippollingactivity_d2d12639d3ae359677d8b3f13d9db3e2.step5_27_circum0(ra_action_cippollingactivity_d2d12639d3ae359677d8b3f13d9db3e2.java:3542)
at com.pegarules.generated.activity.ra_action_cippollingactivity_d2d12639d3ae359677d8b3f13d9db3e2.step5_0_circum0(ra_action_cippollingactivity_d2d12639d3ae359677d8b3f13d9db3e2.java:1317)
at com.pegarules.generated.activity.ra_action_cippollingactivity_d2d12639d3ae359677d8b3f13d9db3e2.perform(ra_action_cippollingactivity_d2d12639d3ae359677d8b3f13d9db3e2.java:158)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.runActivity(QueueProcessor.java:699)
at com.pega.pegarules.session.internal.async.agent.QueueProcessor.execute(QueueProcessor.java:580)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:837)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1048)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:779)
at com.pega.pegarules.session.internal.async.BatchRequestorTask.run(BatchRequestorTask.java:586)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:991)
at com.pega.jsr166backport.java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:532)
at java.lang.Thread.run(Thread.java:722)
