Citigroup technology inc
Last activity: 1 Jan 2017 9:40 EST
Compiling java code in activity step
Below is the sample code which i am writing to retrieve the filename inside folder and subfolder by giving the directory name as an inputs
I am trying to use a user function/method to call the method if the file is a directory. But i am getting the following compilation error. I wanted to know what i am doing incorrectly.
Compilation Error
Test compilation failed: ----------
1. ERROR in /Rule_Obj_Activity_Citi_GCNA_RUSA_FileDownload_getDirectoryContents_Action_20160922T172011_508_GMT.java (at line 388)
public void listFilesAndFilesSubDirectories(String Path);{
Syntax error on token "(", ; expected
2. ERROR in /Rule_Obj_Activity_Citi_GCNA_RUSA_FileDownload_getDirectoryContents_Action_20160922T172011_508_GMT.java (at line 388)
Syntax error on token ")", delete this token
2 problems (2 errors)
Compile failed.
Java Code:
Compilation Error
Compile failed.
Java Code:
String files;
String size;
public listFilesAndFilesSubDirectories(String Path){
java.io.File directory = new java.io.File(Path);
java.io.File[] fList = directory.listFiles();
tools.findPage("TempDirectoryListPage").getProperty(".FileLocation").setValue(Path);
if(folder == null)
tools.findPage("TempDirectoryListPage").getProperty(".DownLoadError").setValue("Either directory does not exist or is not a directory or No Access.");
else
ClipboardPage cp = tools.findPage("TempDirectoryListPage");
ClipboardProperty CPProp=cp.getProperty("FileNamePageList");
for (int i = 0; i < fList.length; i++)
if (fList[i].isFile())
files = fList[i].getName();
size = String.valueOf(fList[i].length());
ClipboardPage CPlist=CPProp.getPageValue(i+1);
CPlist.putString("FileName",files );
CPlist.putString("FileSize",size);
if (fList[i].isDirectory())
Path=new listFilesAndFilesSubDirectories(file.getAbsolutePath());
tools.findPage("TempDirectoryListPage").getProperty(".DirectoryNameList(<APPEND>)").setValue(files);
tools.findPage("TempDirectoryListPage").getProperty(".DownLoadError").setValue("Successfully retrieved the list of files from the above directory selected.");
***Updated by Moderator: Vidyaranjan. Removed user added Ask the Expert tag. Apologies for confusion, shouldn't have been an end-user option***
