Java Step
How to get a property value from clipboard using Java step?
Hi Yatish,
If you are trying to read any property which is available in the Primary page of your Activity then you can use below code,
ClipboardPage primaryPage=tools.getPrimaryPage();
ClipboardProperty prop = primaryPage.getProperty("PropertyName");
If you want to read from the different Page which is available in Clipboard then you can try with below code,
ClipboardPage primaryPage=tools.findPage("pxRequestor");
Hope this will help you.
Regards
Mahesh
There is getString () also available if you want the value in the string format.
tools.getPrimaryPage().getString("property Name");
