"Failed to process passivation queue: java.lang.NullPointerException" "getMaxPageNameLength"
Hi ...we upgraded our environment from 6.3SP1 tp 7.1.9..
we are seeing lot of null pointer exceptions with passivation...below is the exception stack trace...any idea on this?
2016-04-26 12:21:59,793 [ES PassivationDaemon] [ STANDARD] [ ] [ ] ( mgmt.base.NodeRequestorMgt) ERROR - Caught exception during passivation processing: null java.lang.NullPointerException at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.getMaxPageNameLength(DatabaseStorage.java:1463) at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.pageNameIsTooLong(DatabaseStorage.java:1482) at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.passivatePage(DatabaseStorage.java:452) at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.passivatePage(DatabaseStorage.java:531) at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.savePage(NodeRequestorMgt.java:747) at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.processPassivationQueue(NodeRequestorMgt.java:2469) at com.pega.pegarules.session.internal.async.PassivationDaemon.processPassivationQueue(PassivationDaemon.java:365) at com.pega.pegarules.session.internal.async.PassivationDaemon.run(PassivationDaemon.java:339) at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1259) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008) at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:828) at com.pega.pegarules.session.internal.async.PassivationDaemon.run(PassivationDaemon.java:301) at java.lang.Thread.run(Thread.java:745)
2016-04-26 12:21:59,793 [ES PassivationDaemon] [ STANDARD] [ ] [ ] (ternal.async.PassivationDaemon) ERROR - Failed to process passivation queue: java.lang.NullPointerException at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.getMaxPageNameLength(DatabaseStorage.java:1463) at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.pageNameIsTooLong(DatabaseStorage.java:1482) at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.passivatePage(DatabaseStorage.java:452) at com.pega.pegarules.session.internal.mgmt.base.DatabaseStorage.passivatePage(DatabaseStorage.java:531) at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.savePage(NodeRequestorMgt.java:747) at com.pega.pegarules.session.internal.mgmt.base.NodeRequestorMgt.processPassivationQueue(NodeRequestorMgt.java:2469) at com.pega.pegarules.session.internal.async.PassivationDaemon.processPassivationQueue(PassivationDaemon.java:365) at com.pega.pegarules.session.internal.async.PassivationDaemon.run(PassivationDaemon.java:339) at com.pega.pegarules.session.internal.PRSessionProviderImpl
Message was edited by: Rajani Kanth Thakkilipati
Message was edited by: Marissa Rogers - Added Category (4.26.16)
