WellFargo
Last activity: 24 Sep 2018 6:42 EDT
Getting error as "The work object references a different assignment than the current one." when opening the case from WorkList/WorkBasket
I'm  transferring  claim from work basket to Worklist (or Worklist to WorkBasket) and when I try to open the claim from the WorkList , its throwing an error as.
Due to this I'm unable to transfer the claim to different WorkList / WorkBasket
Functionality is working fine for WorkBasket to WorkBasket / Worklist to WorkList transfer
Did anyone face this issue ?
WellFargo
Yes we are using 7.3.1 and at 15th step flow page is updated.
Issue has been resolved now. It was happening because we had customized TransferSelectedClaims and during transfer, it was unable lock the claim and save it.
Now we have included that step and used obj-save and issue got resolved
Thank you so much for the guidance, it helped a lot understand logic behind this
What activity are you using for the transfer? What do you see for the assignment handle on the newAssignPage and the pyWorkPage flow page?
WellFargo
I'm using Reassign activity for transfer.
I can see the assignment handle in newAssignPage but not in pyWorkPage ( My understanding of Assignment handle is that it shows class and timestamp , correct me if I'm wrong)
Vamsi Thatavarthi Jose Navas
The assignment handle is usually the class, pxRefObjectKey, and pxFlowName. The pxFlow page under pyWorkPage should show the pxAssignmentKey. It sounds like the newAssignPage and pxFlow page are not in sync. I am looking at the Reassign activity in a 7.3.1 system and see there is a Page-Change-Class step for the newAssignPage. There is also a step to update the pxFlow page on the work object if the page exists. Can you trace the reassign process and check to see if both the assignment and work page are being updated the same?
Vachan Chauhan Anurathan Kalithasappulavar Hani Elsari Mendrofa
WellFargo
There is a property called pxFlowInsKey in both newAssignPage and pyWorkPage. I can see that both are same
Vinothini J
What about the pxAssignmentKey on the pxFlow page?
Here I have a worklist assignment and my newAssignPage shows the ASSIGN-WORKLIST ... pzInsKey.
On the corresponding pxFlow page under pyWorkPage, I see the pxAssignmentKey value matches my assignment page.
WellFargo
In pyWorkPage pxAssignmentKey property is available but its having value as Assign-WorkBasket.....
In newAssignPage I can see the value as Assign-WorkList...
Both values are not matching
WellFargo
In Reassign activity , we have used step 9 "Page-Change-Class" to change the class as Assign-Worklist
And did you see the step execute to update the flow page? I am not sure what Pega version you are using. In 7.3.1, I see Work-.Reassign in Pega-ProcessEngine:07-10-31 and the flow page should be updated in step 15 if pxFlow exists.
WellFargo
Uddhao Mhaske
Tata Consultancy Services
Could you pleaes provide snaphots of your configuration.
Standard Chartered
If you are already having lock on your case, no need to open the case. But use refresh-And-lock method after your commit happens on pyworkpage.
Hope this helps..
