GET instead of POST in Prod
I have a POST rest call in dev
For some reason in Prod PEGA decided to use GET instead of POST
any idea why that might be
Hi Henry,
In addition to verifying the activity, you can also enable debug logs for "com.pega.pegarules.integration.engine.internal.connect.rest.RESTConnector" to log the request if it is GET or POST. It will also log the response for the request. Hope it helps.
How you are sure that it is using GET instead of Post method, verify activity, it might be calling POST method.
