Facing issue while configuring email account
Show More
Exception caught connecting to email server; java.net.UnknownHostException: pega7: pega7: Temporary failure in name resolution
Show Less
Your User_ID seems to be missing an 'm'?
Any update on this issue whether its resolved or not. If yes then what is the exact issue?
Are you able to ping the particular host? Also check your firewall settings, whether it is blocking any request.
Is your test connection successful?
Did you do the changes at gmail end as well?
Abhinav
Can you try using other Gmail Id's just for testing pupose?
