CMC Markets
Last activity: 4 Dec 2020 11:00 EST
External jar files not being loaded at Pega server startup.
After upgrading from 7.3 to 8.5, and doing a test can see that external jar files are not being loaded at server startup.
There is a list of jar files provided in DSS - Pega-RULES • compiler/defaultPaths, seperated by : and works fine in 7.3
Can see that in the 7.3 startup logs, there is an entry similar to below for each jar:
Jar added to compile time classpath /opt/apps/xxxx-pegacrm/webapps/yyyyy/WEB-INF/lib/xxxx-core-2.6.2.jar
The DSS has not changed but dont see the line in Pega 8.5 start up logs. As a result a number of libraries which rely on these jars are not getting compiled.
Appreciate if anyone has any additional info around this.
Rajesh.
