Errors while running CompileAndLoad.bat file in 6.3 SP1
Getting below errors while running CompileAndLoad.bat file for creating site specific algorithm.
May 22, 2018 4:42:00 PM com.pega.pegarules.internal.bootstrap.PRBootstrap
SEVERE: Problem during method invocation (main)
java.lang.IllegalArgumentException: Must specify a PRCompilerEclipse.DependencyF
inder implementation.
at com.pega.pegarules.generation.internal.compiler.PRCompilerEclipse$Bui
lder.build(PRCompilerEclipse.java:513)
at com.pega.pegarules.generation.internal.compiler.PRCompilerEclipse.mai
n(PRCompilerEclipse.java:581)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBoot
strap.java:349)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropaga
tingThrowable(PRBootstrap.java:390)
strap.java:439)
at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
strap.java:349)
strap.java:439)
strap.java:349)
strap.java:439)
Exception in thread "main" java.lang.RuntimeException: Problem during method inv
ocation (main)
strap.java:445)
Caused by: java.lang.IllegalArgumentException: Must specify a PRCompilerEclipse.
DependencyFinder implementation.
strap.java:349)
strap.java:439)
... 1 more
***Edited by Moderator Marissa to add SR Details***
Upon reviewing the new SR (SR-C37109) I see that this was resolved and SA-59322 Error occurs when running the CompilAndLoad.bat was generated as a resolution.
If you have the same issue, please refer to the SA above.
