Error while running the migrate.bat file . upgrading from 7.2.2 to 8.3
we are upgrading the pega 7.2.2 to 8.3. we are getting the below error while running the migrate.bat file.
please help me if you have any idea on this.
[java] at com.pega.pegarules.install.SQLLoaderInternal.readAndExecuteSQLStatements(SQLLoaderInternal.java:151)
[java] at com.pega.pegarules.install.SQLLoaderInternal.load(SQLLoaderInternal.java:110)
[java] at com.pega.pegarules.install.SQLLoader.loadInner(SQLLoader.java:98)
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:77)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:65)
[java] 2020-04-03 10:46:38,362 ( SQLLoaderInternal) WARNING - Statement: CREATE INDEX rules.indexref_idx01
[java] ON pegaRULES_1.pr_index_reference
[java] (
[java] "pxRuleFamilyName" asc,"pxRuleClassName" asc,"pxInsIndexedKey" asc,"pxIndexPurpose" asc,"pxObjClass" asc
[java] )
[java] (
[java] )
[java] ********************************************************************************
[java]
[java] Encountered a SQL Exception, clean schema before running again.
[java]
[java] Exception in thread "main" com.pega.pegarules.install.SQLLoaderException: Error executing SQL statements
[java] at com.pega.pegarules.install.SQLLoader.load(SQLLoader.java:80)
[java] Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Incorrect syntax near '.'.
[java] at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:216)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1515)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement.doExecuteStatement(SQLServerStatement.java:792)
[java] at com.microsoft.sqlserver.jdbc.SQLServerStatement$StmtExecCmd.doExecute(SQLServerStatement.java:689)
[java] at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:5696)
[java] at com.microsoft.sqlserver.jdbc.SQLServerCon
BUILD FAILED
D:\Pega_8_Extract\116466_Pega8.3_16102019\scripts\migrateSystem.xml:603: Java returned: 1
Total time: 51 seconds
Exiting with Error
