enable agents on multiple nodes from single console/UI
Hi all,
Our application makes use of more than 30 aegnts. Production environment has 8 nodes. Generally the deployment window is of very short time. Imediaetly after jar import and server restart all the agents are disabled so that no processing can happen. Next we enable Migration agents to migrate cases from old release to new relese format. Once that is done we need to enable rest of the agents. This process of enabling/disabling multiple agents on multiple nodes takes long time from SMA. Is there any way a signle console can be provided for multiple agents enabling/disabling on different nodes. It will be even better if it a single console is provided for mutliple environments like UAT, PROD etc. Does AES have these capabilities?
Aniket
***Updated by moderator: Lochan to close post***
