JP
Embedded page list properties are not exposed by running the "optimize for reporting" wizard after application migration (7.1.9)
On dev environment we have optimized a couple of embedded page list properties for reporting.
We migrated automatically created declare-index rule, index calss, index propertis, index table etc to the testing environment without any problem.
However, we found that we can not rebuild the index table by re-running "optimize for reporting" wizard on the testing environment against those exposed properties.
Findings:
1. The column expose JOB completed 100% without any error, and the "instances" number indicates that there are some old work objects (which has been created before application migration).
2. New work objects (created after application migration) have index table records populated as expected.
Questions:
Is this a known issue? If yes, are there any hot fixes available?
Can we re-run "optimize for reporting" wizard against properties, which has already been exposed, for the purpose of rebuilding index table?
Message was edited by: Chunzhi Hong
