Emails with with embedded image in the body are not visible in outlook
Hi Team,
My requirement is to embed QR image in the email body. PEGA generates QR's for each case and put into a image content rule.
I tried these approaches but nothing showing the embedded image in the outlook.
Apporach1: Referring with URL
<img src="env/prweb/datacontent/Image/qrcode/9372235b-aed2-4008-a052-93de5fdcdd6f.png ">
Result: Rendering in the corr attachment but failed to render in web based clients or
outlook.
Reason: The given image path is not global accessable
Apporach2: Referring actual image content
Hi Team,
outlook.
<img src="data:image/png;base64,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 ">
Result: Rendering in the corr attachment but rendering in few web based clients but not outlook.
Reason: Only few web based clients support this and outlook blocks the content.
Apporch3: Mimic image upload via corr rule
When I upload image manually in the corr rule then the image path looks like
<img alt="" data-cke-saved-src="../datacontent/Image/rteImages/Fields1605830891036.png" src="../datacontent/Image/rteImages/SAPFields1605830891036.png" style="max-width: 100%;">
This is rendering in outlook body also it is rendering as an attachment in the web based clients.
So I tried to mimic the same approach. Generated QR images /rteImages/ path and exactly mimicked the same img tag but still it is failing to render in outlook and web based clients.
I have seen the below article to generate to use cid in html body but I am not very sure how to add content-id for the attachment.
https://collaborate.pega.com/question/sending-messages-inline-images
Version: 7.4
Using OOTB send email shape to send emails.
Your help will be much appreciated.
Satish
***Edited by Moderator: Pooja Gadige to add support request details***
