Dynamic Folder in CMIS
Hi Good Morning/Good Day/Good evening,
dear Pega Expert,
please help me, does anyone know how to make dynamic folder in CMIS (i'm using openKM) when i attach files in Pega 7.2.1?. my condition right now is already connected between Pega and OpenKM, thereafter i successfully attach files on Pega and then files are save in root directory OpenKM. the problem is i have different category type of files and i want files are saved properly in folder base on the category type (e.g : excel file will save in excel folder, pdf file will save in pdf folder, etc).
now, i've done a few ways to try and the status are :
1. create openKM-Pega.jar file with expectations has functions and methods as brigde between Pega and OpenKM to communicate and make dynamic folder. the file openKM-Pega.jar already imported to Pega in Designer Studio - Application - Distribution - Import. afterwards i try to create an integration in +create - Integration Connectors - Connector Java but i get confused when i want set the Integration using Connector Java because there was no methods/functions which was set in OpenKM-Pega.jar. did i take wrong ways to create an integration? i really need suggestion about my problem, please help me :( . because i'm just a newcomer whom less of experiences using Pega.
regards,
Pieter Valdano, Jakarta, @ID
dear Pega Expert,
regards,
***Updated by Moderator: Vidyaranjan. Removed user added #helpme and Ask the Expert tags. Apologies for confusion, shouldn't have been an end-user option***
thank you very much Mr. Kevin Zheng for your fast response to reply. i will try to develop it with Connect REST. thank you very much, God speed and bless you.
regards,
Pieter Valdano, @JKT, @ID
