Rule-Connect-CMIS FileNET
Hello PegaSystems,
Saw some similar posts but what is a solution or remediation when this error occurs:
2018-10-08 13:30:37,095 [REDACTED] [TABTHREAD0] [ ] [ REDACTED:01.05.01] (nvoke.Rule_Connect_CMIS.Action) ERROR |REDACTED|Rule-Connect-CMIS.CMIS-ServiceData.FileNetDocuments REDACTED - com.pega.pegarules.pub.services.RemoteApplicationException: Failed to search for duplicate document: com.pega.pegarules.pub.services.ConnectorException: Failed to create document: org.apache.chemistry.opencmis.commons.exceptions.CmisInvalidArgumentException: Bad Request,com.ibm.ecm.cmis.exceptions.InvalidArgumentException: CIL1145: The service cannot be completed because the value that was specified for the following input parameter is not valid.
***Updated by moderator: Lochan to update platform capability***
Can you please share details of Connect CMIS rule? Is it Atom or SOAP binding?
What is the flow where this integration is being used?
Are you able to perform the same check using the client UI provided by Chemistry?
