crazyminds
Last activity: 22 Jun 2020 7:45 EDT
Display weather from free API on PEGA ui
can someone provide mee detailed steps on how to display current weather conditions from any free API using connect rest in pega???
plz provide me the step by step detailed explanation how to show weather on my ui for a selected city
BlueRose Technologies
I have Created The same you saying but it is showing following
Error.
crazyminds
sir can u provide step by step document how to use openweathermap to integrate in pega???
crazyminds
please can u provide me step by step procedure how to implement it.
thanks for help
Hi ,
Please follow the below link where you can find steps to create rest connector in pega.
http://myknowpega.com/2017/06/07/connect-rest-configuration-tutorial/
In place of endpoint URL , provide the weather api URL suggested by sahuv1.
Thank You,
crazyminds
Im unable to implement it
I BEG SOMEONE TO PROVIDE STEP BY STEP PROCEDURE TO RETRIEVE WEATHER INFO USING CONNECT-REST.
LTI Mindtree
Hi Kranthi,
Please refer the below link, she explained step by step configuration of Connect-Rest for retrieving weather report
https://collaborate.pega.com/discussion/build-rest-connector-and-display-values-pega-case
Regards
KC
crazyminds
Please find the steps below.
Go to Designer Studio -> Integration -> Connectors and click on Create REST Integration
Provide Name and endpoint URL(weather api URL)
Checkbox for dynamic value will get enabled if there is some dynamic property
Click next
Provide resource Name and click the checkbox for the method supported then next.
Provide sample response by clicking on +Add a Rest response or +Add a fie
Then click on next.
Review all the data and click on create.
Once 100% get completed click on close.
Click on the datapage (D_servicenameyouhaveprovided)->action ->run->provide input value ->run.
See the result.
Thank You,
Go to Designer studio-->Integration--->Connectors--->Create Rest Integration
Enter below details.
1.Name:Enter the name of the system,Which you are going to consume the service.
2.Endpoint URL:(Your weather url that you want to consume).
3.Resource Path:It will be pre populated if you enter the complete url.
4.Headers:It is not required for you.
5.Authentication:If mandatory then select basic.
click Next
since you are fetching the reports so select GET method.
click Next.
Click on Add a rest response.
Run
Next
Finish.
PRPC will generate the required classes automatically.
Please let me know If there is any query.
Abhinav
PFA for the step by step documentation with screen shots.
I have done this, still it is showing error when I Preview or when i am trying to create the Connect Rest.
I am giving SC for the same, if Anyone Knows why this happening Please let me know.
Thanks and regards
Pradip
Hi ,
This is the weather API which you can use :
https://openweathermap.org/find?q=hyderabad every time you need to replace the city name while preapring your query and then Using fetch get the results.
The response you can use as :
${weather.main.temp}
${weather.weather[0].description}
${weather.name}
