Designer Studio & Deploy to Server
Hi all.
I'm trying to integrate Designer Studio with Package Server and Robot Manager in order to "Deploy to Server" from Designer studio.
This is my configuration
CommonConfig.xml
<Servers>
<!-- enabled= "true" connessione con il robot Manager & Publish to server -->
<!-- RPA="true" ???? -->
<!-- baseURL="http://localhost:8080/prweb" url di Pega Server -->
<!-- authenticationType ??? -->
<Server name="RobotManager" baseURL="http://localhost:9080/prweb" enabled="true" proxyAddress="" RPA="true" authenticationType="Basic" workgroup="Customer service" robotName="Cust00"/>
<Server name="Config" baseURL="https://omc.openspan.com/" enabled="false" proxyAddress=""/>
<Server name="Intelligence" baseURL="https://WFIID-wfi.openspan.com" enabled="false" proxyAddress=""/>
<Server name="IdP" baseURL="https://HiroAuthServer.com/Endpoint" enabled="false" proxyAddress=""/>
</Servers>
StudioConfig.xml
<Robotics>
<!-- baseUrl: Address of Pega API endpoint -->
<PegaServer baseUrl="https://localhost:8080/prweb/api/v1/" />
<RDA_Credentials userName="Admin@BankerPro" password="rules"/>
<!-- PackageServer baseUrl: Address of the Package Server API endpoint. -->
<PackageServer baseUrl="http://localhost:5000" />
</Robotics>
RuntimeConfig.xml
Hi all.
CommonConfig.xml
<Servers>
</Servers>
StudioConfig.xml
<Robotics>
</Robotics>
RuntimeConfig.xml
<Robotics>
<PegaServer baseUrl="http://localhost:8080/prweb/api/v1/" />
<LocalApiService enabled="true" SSL="true" port="9443" allowedOrigins="*" JWTSecurity="false" PegaServerURL="http://localhost:8080/prweb/api/v1/" /> -->
</Robotics>
I am run the Package Server:
PackageServer.exe --urls “http://serverHostName:5000”
and
ServerStatus.exe --urls “http://serverHostName:5005”
I am launch Designer Studio and I have to enter user and password... but what?
Are not the user\password use to connect Pega Platform (eg. admin@bankerpro\rules)?
Can you help me?
Marco
Hi Marco,
My issue got resolved, the issue is PegaRobotManager is not installed correctly.
So i reimported the package again then i could able to connect to the pega server from robotics stuido.
Som
