U.S. Bank National Association
Last activity: 13 Sep 2016 23:37 EDT
Deleted column of an optimized property came back
We encounted a problem (V 6.2 SP2) :
There is an existing property which has been optimized for classes, and later the column has been removed from the respective tables.
Recently we saved as this property into higher RSV and just updated the max length.
Then we found that the coulmn has been exposed again into the tables.
Could you please suggest how did this happen ?? We haven't done any optimiation using wizard/any utility. It was just a save as of the property.
***Updated by Moderator: Marissa. Removed user added Ask the Expert, #helpme, and FAQ group tags. Apologies for confusion, shouldn't have been an end-user option***
Hello Karthik,
How did you remove the optimization on the property? Do you still have column population jobs assocatied to the properties?
