CRM.EXE gives an error when calling through Windows Adapter (Windows 7 Professional, Robotics Studio version 8.0.1039.0.)
I am enrolled in Pega Robotic Automation Architect Essentials, working on "Working with Windows Adapters". I’m running on Windows 7 Professional with Robotics Studio version 8.0.1039.0.
I’ve got a problem with the interrogating with a windows application. When I try to start interrogation (in this case the Path has been set to CRM) I’m getting the following error: "CRM.exe has stopped working". See the attached screenshot.
When I start CRM.exe manually it works without any errors. See the attached screenshot.
With IE, Notepad and Calc I get the same error, but when I give in the Path a TXT file or XLS then it open the application without an error.
Any help would be great!
Regards Carlos
--- Error Message
Regards Carlos
--- Error Message
