Correspondence Fragment WorkLink
I have 2 questions about the link to Work object in email notifications. As far as I know the general way is to use Correspondence Fragment WorkLink • Email here.
In our project we use SSO authentication with Active Directory, so the login page is not shown.
We tried to use the Correspondence Fragment WorkLink and found the following questions. Could you please give an advice how to resolve them?
Question 1: Due to security requirements each user should accept "Terms of Use" before he can work with work items. When a user opens portal he sees a "Terms of use" popup window with check box to accept(see Terms Of Use.png file).
There is a short description of the current implementation of "Terms of Use" acceptance:
1. Section Data-Portal pyPortalHeader has a link, which shows "Terms of Use" popup windows(Local Action).
2. Section Data-Portal pyPortalHeader includes a script, which fires when a page is loaded. This script emulates a click event on link(see the previous point) to show "Terms of Use" popup window.
3. Popup windows sections contains a checkbox to store information in OperatorID page if "Terms of Use" are accented or not.
The question is: we want to show "Terms of use" popup window when user opens Work object by link from email. How we can do this?
Question 2: By default, WorkLink opens only the specified work item on Review harness. Is it possible to open all user portal?
Thank you in advance.
