Collect Employee Info Step Disappears after adding Utility field
In the Exercise to "Add the addWorkObjectParty activity to the Create Employee Record process", I'm running into an issue after adding the Utility step to "Create Employee Work Party". After saving the process flow, the step "Collect Employee Info" is no longer displayed in the Life Cycle view.
I've tried to delete and re-create the Process "Create Employee Record", but the same thing occurred.
Has anyone else seen this occur? How do I correct this issue?
